Rbob
Ok,
I installed the backglass by myself, it was a ***** to do and will pull it out again and do it again with some help.
I cannot get the weatherstrip seal to cover the headliner teeth on the inside and the lockstrip out the outside of the glass will not fit all the way on the lower rear corners. I was pissed off, hot and tired when i gave up last night.
I did not rope it in, which was the *****, (used the plastic bone). Also I started the lockstrip and the top center, which I will start the lockstrip next time on the bottom.
Pushing done on the back glass helps roll the weather strip, but I think it will help with someone on the inside (pull the gasket into place) while I am tapping it from the outside.
Don't know what else to do, just pissed off right now.
thanks for your help and ideas,
