Backing plate swap
my5thmopar
Life Long MOPAR Owner
Tennessee
If I change the backing plate, drums, and hardware on an 8 3/4, will it change the axle width? Reason: The drums are hard to get on my truck project and I was going to switch to CBody stuff. I only have about 1inch between the tire and the spring and didn't want to cause more issues. Any advice before I go this route? Craig
Think about that for a minute.
The wheel mounting surface doesn't change, so how could it be a different width?:D
Maybe if you swapped axles it could end up slightly different.
See what happens when you don’t think. Doh.
