StreetSleeper
H116cp pistons wrist pin and rings are lighter than stock 360 pistons (360 pistons alone weigh 584 grams, LA pins 153 grams? LA rods 758 grams?
H116:
Aftermarket I beam rods are lighter than stock…Weight is approx. 595 grams, for the I beam for the small block Chrysler
Using a stock 360 crankshaft
Will internal balancing still require ADDING Mallory metal despite the weight reduction of aftermarket pistons and rods?
Stick shift street application but I have caught air over some train tracks and my heart almost matched the engine rpm sky rocketing into oblivion-didn’t lose the engine despite myself.
Yes I plan on using a RPM governor, This time.
H116:
Pin Weight Gram | 154 |
Weight W Pin Gram | 736 |
Weight w/o Pin Gram | 582 |
