Ball joint size?
mikedevore
Oklahoma
Can someone give me the size across the flats for the 1973 & up A-body joint?
How about the earlier joint?
Trying to find out which upper control arms I have.
I'm looking dor the meashurement across the flats.
Thanks for your help.
You don't have to measure like that.
Here's another "trick" for everyone.
If the thread diameter of the stud is 7/16, they are the 62-72 small ball joint.
If the thread diameter of the stud is 9/16, they are the 73-76 big ball joint.
Use a 7'16 and 9/16 open end wrench and put it around the threads.
Easy enough to do, and check that way, if your eyeballs aren't up to see the difference.
