OK, the bushings in the upper control arm are done. Now is there a trick to removing the ball joints. It looks like they screw in but I'm not sure.
Thanks again for your help.
[ame="http://www.amazon.com/Alltrade-648749-Specialty-Joint-Socket/dp/B0028QGT8Q/ref=sr_1_1?ie=UTF8&qid=1314723144&sr=8-1"]here is a cheapy ball joint socket set i got for mine that works.[/ame]
