ball joints
69wacuda
Handling, and a 500ci engine.... All in good time!
Washington
What are the actual sizes of the large and small ball joints. are all disc brake setups large or are there ever stock small ball joint disc brakes???
thanks
I can't tell you the actual size of the ball joints, but Kelsey-Hayes four-piston fixed caliper disc brakes were an available FACTORY option from 65-72 and used the small ball joint and small bolt pattern wheels.
All 73-76 a-bodies used the large ball joint, but some slant six cars used small bolt pattern drums. All disc brakes from 73-on (RWD stuff) was large bolt pattern and used the large ball joint.
