G gotdust57@yahoo Well-Known Member Joined Aug 18, 2006 Messages 346 Reaction score 2 Mar 18, 2007 #1 do i need to run a ballast resistor with a pertronix ignitor 2 with flame thrower in my 73 duster with 360 motor? thanks
dgc333 Well-Known Member Joined Jan 12, 2005 Messages 4,098 Reaction score 53 Location Pembroke, MA Mar 18, 2007 #2 If the coil recommends one then yes. The pertronix igniter is just an electronic switch much like the the mopar ecu, the need for a ballast resistor is a function of the coil you are using not the control module.
G gotdust57@yahoo Well-Known Member Joined Aug 18, 2006 Messages 346 Reaction score 2 Mar 18, 2007 #3 thanks
T ted_sweet Well-Known Member Joined Aug 4, 2004 Messages 708 Reaction score 11 Location albany NY Mar 20, 2007 #4 if using the pertonix coil you dont need it.
