[FOR SALE] Barn Find 1967 Barracuda Commando
MidnightSwinger
Woodland CA
Original miles, real Commando survivor car. Have all of the original parts except the small bolt steel wheels. Was a 1 family car until I got it.
I pulled this out of a barn in Sebastopol 3 months ago and got it road worthy. It was originally from Montana and has some rust in the trunk,and lower quarters but is solid otherwise. Floors and frame rails are solid and still have blue paint showing on them.
Upgrades include:
11.75” Disc Brakes
Firm Feel Torsion Bars
Drag Shocks
Fully rebuilt front suspension
Solid Tie rod sleeves
Adjustable Strut Rods
Boxed lower control arm and Delrin bushings
Rebuilt rear suspension, new leaf springs
New poly bushings for rear suspension
Fully rebuilt 8 3/4 rear with 3.91 Sure Grip
Real 340 Exhaust Manifolds
New Edelbrock AVS2 carb
Brand new full dual exhaust
New brake lines/master front to rear
New reproduction floor mats ($250)
New Indy slot mags/tires
Included parts:
New front windshield and gasket 68/69
New carpet kit
Stainless 68/69 windshield trim and clips
Stainless 68/69 rear window trim.
$15,000 located in Woodland CA 95695
Forgot to add it has a new fuel tank/sending unit and related gaskets/seals. Here are a few shots when I pulled it from the barn.
The disc brakes upgrade appears to be large bolt pattern ? Also wheel studs seem extra long ? Are the rear axels small bolt pattern or large ? Also you state "original mileage" but either I missed it or can't read it off the photo of the dash ? Can you please let me know. Thanks
How does the engine run? It looks all original and untouched, except for your new carb/exhaust manifolds.
Any problems with the engine/trans?
And as Bennoel asked, what is the mileage, since it's not showing?
LBP all around. 3 inch wheel studs all around. 87,*** miles. It goes up as I drive it frequently.
87,*** miles, goes up as I drive it frequently. Runs and drives great, smokes a little white/gray smoke when you go WOT. But it’s almost 60 years old with the original rings so that is to be expected. I’ve taken it to redline in 3rd gear without a hiccup. Pulls hard.
Here is the ugly, the trunk extensions are gone, the spare tire pan is actually pretty solid. The deck lid is solid, one spot of surface rust pictured. The gutters are nice and clean. I think this was a case of a bad trunk seal and the rubber mat trapped moisture. The floors and frame are solid.
Switched to steelies and dog dishes in the front. 15x6.5” oem wheels. Working on finding a rear set.
Open to serious cash offers or trades.
