It looks like your emblem (s) need to be restored. I took a flat board and stretched a cotton rag over it tightly held. I spray painted the front of the emblem with flat black paint. After it tacked up but was not completely dry, I sprayed carb cleaner over the rag. Then I carefully laid the emblem down flat on the board and wiped it across in one direction. If the paint is not completely removed from the high spots, repeat on a clean area. Wipe off the edges on the board and it should look perfect.
