Turned the Dart on today and after warm up Battery was very hot. exchanged the battery and the new battery also became hot. Changed the VR as well and still same issue. Any Advice what to try next? Thank you
I ask because the electronic regulators control the output through the case ground to the firewall. I replaced the old point type regulator with a new electronic one that was poorly grounded. I boiled the battery and blew out some bulbs. It could have been worse.Good evening. Changed the VR after the issue of the battery.
These are big clues!Thank you Mike. I have and also the Ammeter is jumping and the needle is buried to the C side at times.
^^This is a great test^^ that can be done without a multimeter.Pull the VR connector off and see if it keeps on charging. The green wire brush may be grounded in the alternator. Neither brush with field wires disconnected should show continuity to ground.
Gosh yes.Good evening. Checking the lights now. Also can a loose alternator belt cause the issue? Thank you
Any steps on the volt checks?
