Battery cable/mini starter question
Thanquol
New Member
Wisconsin
Got a 67 Dart with a humble 273 with a Dakota mini starter with the original 67 battery cable hookup. The starter has the cable relocation kit. I’d like to keep it.
The problem is the SB cables just barely fit on the starter including having to pull the cable out of it’s firewall bracket. The cable is getting worn and needs replacing anyway.
Yes, I know I can make my own but I’d rather get an OEM cable replacement with the cloth heat cover and rubber protective cable boot. I don't know anyone that sells just that cloth heat cover and rubber boot by itself or I would make my own. It needs to be about 5-6” longer it seems.
Will a S6 cable kit be a bit longer? How bout the BB cable? Will a B body cable be longer? If so, which one?
Anyone else deal with this and manage to get a new OEM cable kit to fit properly?
TIA!
