mopardemon340
where did everyone put the battery when they did the magnum swap and kept the serpentine belt system.
not using the ac and not using a delete pulley we cut that part of the bracket off.. thats y i need to keep the truck ps bracket it a lower the ps it will cause my belts to rubare you keeping the ac pump or are you just not using the ac delete pulley?
