Battery & Starter Cables
domdart
Johnstown, PA
Where do you run the positive battery cable to keep it away from the headers? I have a 68 Dart with a 340 and Doug's Headers. Thanks.
I added a few pics. My original slant 6 battery cable is pulled tight from battery to starter. I had to move the battery to the edge of the tray to reach the starter on the 340. Do I route the new cable down the fender to the firewall then the starter? Does it go down the inner fender to the shock tower then to the starter?
I bring the cable in from the firewall side. Run it on inner fender, down firewall, then forward to the starter. If it's a mini starter, is the standoff piece removed?
That whole black "thing" sticking out. On most those starters, it all comes off and leaves two studs similar to the older "big" wound field starters.
