gdizzle
I am replacing battery cables, was able to replace the Ground side without issue. However the hot side currently has 4g heading directly to starter, but also has a 8g heading to the starter relay (mounted on the firewall).
The issue is buying a replacement cable, has the 4g, then has a pig-tail which is only 10g.
Is it safe/acceptable to run a 10g wire to the starter relay, instead of the current 8g?
Or is it safe to use my current 8g (old)wire, cut it and splice it to the 10g pig-tail from the battery terminal?
