Baxter oil adapter on a pentastar v6
diymirage
HP@idle > hondaHP@redline
michigan
A few weeks ago i bought the wife a new mom car, a 2018 journey with a 3.6 pentastar
This engine uses an element filter instead of a spin on, which is located on the top of the engine
There is no drain back valve, so no oil in the top at start up
I came across a product that converts it back into a spin on set up WITH drain back valve
What are you guys' thoughts on this ?
There is no anti drain back filter in the world that will defy gravity.
I don't care what it is. It's not gonna stop the flow of oil being upside down.
ok, help me understand this...why not ?
i got valves in my tires that hold 75 PSI of air in, why wouldnt a similar valve work to keep 15 psi of oil in?
(figuring atmospheric pressure is 1 bar, is 14.5 psi)
im not trying to be obstinate, im just trying to understand it
The engineers of that engine put a canister filter on it by design. I don't understand how you think you can improve on it for one thing. Secondly, I've never seen a filter with any sort of anti drain back valve that was 100% leak proof, especially when the filter installs upside down. Like on a slant 6.
