Really?!?!,, cool!??!... thanks!! ;)
ok, no, Seriously. It's a stock Hurst shifter from a van but its not the two bolt style..it's the "bayonet" style, whatever that means. Hurst's site says..
"I would like to get the stick from my OEM shifter re-chromed. How do I get the stick out of the mechanism?
OEM shifters used a "bayonet-style" stick, held in with two metal clips and rubber isolators on each side of the stick. To remove the stick, place or push a steel shim or feeler gauge down each side of the stick, at the bottom where the chrome handle goes into the mechanism, and pull. Should you need new clips and isolators, they are available through your nearest Hurst retailer or through Hurst for a nominal charge."
Can't "see" the clips and I'm concerned about just pulling bolts out of it..
