Bbp disc conversion and cragers?
Duster 72
Thompson falls Montana
Bought a bbp disc conv for my 72 duster and I want to run my 14 inch cragers however it says they won't fit. Bought the kit from Mancini racing is there anything I can do to make them work? What's the clearence issue?
I was able to use 14 inch Cragars on The Right Stuff kit. Just couldn’t use the stick on wheel weights
Does you wheels have tires mounted? If not mount them up and see if they clear. Is you kit made my MBM.
I had to do some polishing off of my calipers at the lead on and lead off edges to keep my Cragars from rubbing. Also had to use spacers to get the wheels out away from the spokes where they're welded to the wheel. The welds are pretty healthy and the beads would rub against the side of the calipers at the top. My kit came from SSBC.
