Cart is in front of the horse but here goes....
I am going to be purchasing 1965 Barracuda for my daughter from a good member here (70% my money, 20% Grandpa's, and 10% hers). All three of us, plus my 12 y/o son, are very excited. I will shut up about the specific car because heaven forbid something prevent the sale. I have never had an SBP car so I'm unfamiliar with the nuances.
On to the meat and potatoes, if not for said car but for general knowledge.
Prospect:
Small Bolt Pattern car, front and rear. Manual brakes.
Parts on hand:
Front -
Donor parts from my 1973 Duster. Front and rear. I recently swapped to a Doctor Diff 11.75" front kit.
- Rotors
- Calipers
- 73+ spindles
- 73+ OEM upper control arms-
- Large ball joints
- QA1 Dynamic strut rods.
- Aluminum 15/16" master cylinder
- Pair of front Hotchkis/Fox front shocks
Rear - 8.25 / 3.21 rear out of my 1973 Duster.
Brakes:
Large bolt pattern 10.95" discs.
1996 and later Jeep Grand Cherokee brakes
Needs:
- Flex hoses
- Brake line
- Moog Problem Solver upper ball joints
- Wheel bearings
- 1996 Jeep GC rotors/calipers
- Rear caliper brackets
- LBP 15' Rallye Wheels (wheel spec and tire suggestions welcome
- Rear shocks
- U-bolts
- Shock plates
- Driveshaft
Please, list any additional needs or comments/tips.
Questions:
Some questions I have surround around the Jeep Grand Cherokee brakes. These are widely regarded as the easiest brake swap on an 8-1/4. How does the caliper mount to the rearend? I have read in searches , " Just go buy any 1996 or Grand Cherokee brakes. I assume there is a Jeep caliper bracket or a custom fabricated bracket. I can't find the brackets anywhere. I would like to pick up a Rock Auto caliper and rotor kit but there has to be a bracket out there somewhere.
Anyone got anything on re-using a '73 Duster / 8-1/4 driveshaft? If it is longer I can just have it cut, right? Yoke's the same?
I'll also be looking for a large sway bar and 1.03 torsion bars, used. If I could find some used tubular upper control arms that would be awesome! I am cleaning out my stash and trying to keep this as cheap as possible. By using the parts I have I would like to keep it manual so I don't have to buy power brake components and we will go to 15" tires for availability and longevity. Another thing that is a bonus is that while doing the driveshaft I will get rid of the ball and trunion.
Thanks in advance.
Prospect:
Parts on hand:
Front -
- Rotors
- Calipers
- 73+ spindles
- Large ball joints
Brakes:
Needs:
- Flex hoses
- Brake line
- Wheel bearings
- Rear shocks
- U-bolts
- Shock plates
- Driveshaft
Questions:
Thanks in advance.
