Beehive Springs for sale
ken5124
65 Valiant Signet
Winnipeg, Manitoba
Comp Cams 26995 springs, 795 retainers and 626 locks. 10 degree
These are brand new. I screwed up and they won't work on my engine.
Located in Winnipeg, Manitoba, Canada.
Looking to get about 250 Cdn Funds for everything
Purchaser pays all shipping costs.
What are they supposed to fit?
Comp Cams 26995-16 - Comp Cams Beehive Valve Springs Details
Universal Beehive
Designed for hydraulic or solid flat tappet cams cams as well as hydraulic rollers
.600" maximum lift, 1.415" O.D.
Great for Pontiac, Oldsmobile and Small Block Chrysler or other applications that require shorter installed height.
Specs
OD: Top 1.065" Bottom 1.415"
ID: Top .650" Bottom 1.000"
Seat Pressure: 137 lbs @ 1.700''
Open Pressure: 305 lbs @ 1.100''
Coil Bind: 1.040"
Spring Rate: 280 lbs/in
:brave:
Well that sucks Ken. How is the little beast otherwise? We have to get out for a run sometime.
Certainly does suck.. but better to find out that my cam can't handle it now before the motor is assembled..
It sucks more because Comp Cams said it would work.. My machinist and I were looking over some things when I realized that I was at over 150 pounds pressure , closed, with my installed height of 1.620..
Anyway... dreno... still working hard at my upgrades..Give me a shout !!
Goal is to have it all back up and running by June 30th.. THis year.
Universal Beehive
Specs
Coil Bind: 1.040"
:brave:
Thanks for inserting this, I was out for mothers day lunch !!
Ken
Ken have you investigated to see if retainers that give you a taller installed height are available? I did that with mine to gain .100" installed height. You could also have the heads machined to allow the springs to set lower for more installed height. In fact doing it that way you could customize the spring pressure to exactly what the cam calls for. I did that on an engine a few yrs. back and it wasn't very expensive. Don't remember exactly how much but I'm sure it was less than $100
