????? before I try to degree my cam
earthmover
in the tire smoke
nc
I plan to use the timing chain tension on this motor do I need to get it all in one 1 and take the pin out before I degree or do I wait to pull the pin....I had a little more slack in the chain than I thought was normal but it's not in the chain I replaced it and the new one is the same as the old one and its for line bored main....also I have googled how to degree cams so many times but there are I think 2 ways I read to do it I know I start off by getting true tdc piston stop in plug hole turn motor then the opp. and / the 2# and move pointer..what way do you guys do it???Its my first one....:read2:
