bellhousing/flywheel
ERACER
Oxford, ME
I am getting ready to build an engine test stand and will need a bellhousing and flywheel in order to mount the starter and turn the engine over. In the event that I can't find an LA engine setup, will a Magnum setup work? The first engine I will run is an LA 318. The bellhousing/flywheel setup will be used on the stand only and not in a vehicle.
Don't see why not as I thought the bolt pattern was the same for all the small blocks. You would only run into a different pattern with the big blocks.
Yeah I'm pretty sure the bolt pattern is the same, but wanted some varfication from some of you guys. Is the 5.2 Magnum internally balanced like the LA 318s, making their flywheels interchangeable?
