1. Richard Bryant
    Richard Bryant New Member
    4
    0
    Jun 14, 2020
    Cave junction
    Local Time:
    6:25 PM
    can someone tell me what bellhousing would work in my65 dart I’m putting a 65 poly with an A body 1965 A833 four speed, would a 68 318/340 dart la engine bellhousing work I want to use a 10.50 flywheel and clutch setup.
  2. 65 Dartman
    65 Dartman FABO Gold Member FABO Gold Member
    11,315
    2966
    Sep 24, 2006
    Strasburg, VA
    Local Time:
    9:25 PM
    I can’t answer your question but will comment on your engine choice. A poly is a pretty wide engine; IIRC wider than a 440. A 440 is a really tight fit in the narrow early A engine compartment; a poly might not fit!
    • Agree Agree x 2
    • Oldmanmopar
      Oldmanmopar Going left turning right FABO Gold Member
      8,404
      4571
      Jan 8, 2009
      Danielsville Pa. 18038
      Local Time:
      9:25 PM
      To put a later bell in a 65 Barracuda we had to trim the firewall to floor pan seam.
      • Agree Agree x 1
      • 66fs
        66fs FABO Gold Member FABO Gold Member
        4,798
        1497
        Sep 9, 2009
        Greenwood, South Carolina
        Local Time:
        9:25 PM
        I didn't have to trim my seam in my 64 Barracuda for a 71 340 belllhousing. Brewers has the conversion parts to run a 68 up bellhousing, flywheel and clutch in an early A.
      • barbee6043
        barbee6043 barbee 6043 FABO Gold Member
        12,623
        5258
        Jul 20, 2008
        Shepherd, Texas ( SE Tx)
        Local Time:
        8:25 PM
        Yes call Brewers they will give you the details for what works, ie bell, fork bracket (pivot) , fork, Z bar. They have the knowledge and all big and small parts needed.
        If not mistaken the LA engine SB bell will bolt right to the poly. I also plan to use a 10/1/2 fly. I will do that in a 62 Dart (B body) if I ever get to La. for the trade for the engine.
      • Richard Bryant
        4
        0
        Jun 14, 2020
        Cave junction
        Local Time:
        6:25 PM
        That’s fine I’m installing a complete 67 floor pan, some massaging will be needed, full 65 floor pans are non existent.
      • Richard Bryant
        4
        0
        Jun 14, 2020
        Cave junction
        Local Time:
        6:25 PM
        Yes thats where I’m sourcing mine 68 318/340 2843887 .
      • Richard Bryant
        4
        0
        Jun 14, 2020
        Cave junction
        Local Time:
        6:25 PM
        It fits with about 2” on each side,I’m fabricating fenderwell headers so that won’t be an issue manual brakes no problem there.
