I would think that any early a-body 63-66 2-door bench seat would work, may have to drill new holes for the studs or it may even line up with holes already there. But either way the bench seat should work just fine. Another thing to consider is the seat belts, I think they are different for bucket seat cars, if so you will need seat belts from the same car the bench in from, to be more correct you need the belts from a 1966 Valiant/Dart with a bench so the buckles match the rear.
