joedart
What would cause bent push-rods on 1,7,2,and 8 cylinders on the exhaust side of a 440 and perfectly straight on all the others? 294-530 crower cam and compcams adjustable rockers with the recommended push-rods.
Motor sat assembled for about a year.or at the wrong installe height on those cylinders.Did the engine sit assembled for a long time with the valve springs compressed on those cylinders?just a thought
452's with compcams adjustable rockers. The guides were cut to accomodate this stuff. I will have to mock everything back up and check it all again.What is the guide clearance? What heads? What rockers?
You could have had spring bind too.
