69MOPE
What is the best timing chain I can use at any cost?
milodon gear drive set up
I just looked at the 440 source and it says it has a bearing but does not say if the block needs machining. Do you know?
With 900 hp and 400hp shot of spray I would look some where else then 440 source.
