Rapid Robert
Is one brand in particular recommended?
Who sells the tool you have pictured.Totally agree with that then I have a burnisher for them. to lock the bushing in. Not a cheap tool for what it does. You would be amazed at stuff that is sent to me.
Sizes them when drawn out after tapping in place. But yes, works well. I have the same one.here is the installation tool my son uses from (Proform Factory Performance) it installs the bushing and cuts it to size as its installed.
Yes you are correct it cuts it on the way out. Tap it in and draw it out with the nut.Sizes them when drawn out after tapping in place. But yes, works well. I have the same one.
When Direct Connection [ now MP ] started selling parts, I bought the chrome moly intermediate shaft. And used it with a factory bronze bush. Bad mistake. I was doing a lot of drag racing then, changing cams often.
CM is a hard metal, but not hardened. The original factory shaft was hardened steel, like a shaft out of a gearbox. The bronze bush chewed up the softer CM shaft. I only use alum bushes with the CM shaft.
Thats good news because I have two new ones installed and just assumed they were ready to use.I have the proper tool, but most aftermarket bushings, Melling, Durabond and such are already sized. Once installed, they are already the proper size. Just install them, drop the intermediate shaft in and go.
