67fishfastback
what is the best and easiest dist. to go with on a mid level street car w/ a 360?
The MP distributor is fully adjustable for mechanical and vacuum advance, this would be easier than recurving an OEM distributor. They cost about $160.
what about the MSD ready to run dist.???
It's not worth the extra $$$ over the MP. You did say "street car". Ma Mopar made some pretty good parts. It amazes me that most new guys won't accept that fact.
does the msd dist eliminate the ecu
I don't think its about "accepting" grumpus. Before I found this site I relied on Jegs and Summit to see what parts were available for my car. When I do a search for dist on my car, Mopar doesn't even come up as a distributor option on Jegs site. Only Mallory, MSD and Crane
Which led me to buy the MSD R2R.
This site is a huge eye opener and I thank you guys for helping us new guys.
Wes
The pertronix if used with their coil does not require a ballast resistor.
If you type distributor in the search field, then choose engine size 6.3L 383
Mopar does not show in the results.
Even if I search by vehicle type and select distributor it does not show in results.
