How high HP are we talking here?wondering who makes the best mrchanical fuel pump for a high horse small block and one that has the biggest fittings on it
I run this one with 3/8 line and 3/8 pickup works great:
http://www.summitracing.com/parts/crt-m6270/overview/make/plymouth
Carter 6270 'strip' pump. 120 GPH, puts out plenty of pressure, you need a regulator with it.
... the Carter 6270 will get high enough (6.9 to 8.1 psi) to require a regulator....The pump was always on the ragged edge of overfilling the fuel bowls and causing the carb to run rich and occassionally flood.
These pumps look pretty nice. Doesn't look like they have any mopar pumps listed, but based on some of the pump pictures. It looks like they start with a factory style pump and just modify it with their own inlet and parts.
Might be worth a call over to them if your serious about a nice mechanical pump.
http://www.robbmcperformance.com/products.html
Wouldn't help if the passages behind them are only 1/4 ".wonder if you could tap the inlets for a bigger size , I have one of the older carters:blob:
Demon408 - Thanks. One day I'd like to reduce the text and add more pictures but I never get around to it.
There are some clever solutions to shutting down electric pumps during accident situations for those who go that route. But my preference was mechanical as I wrote there.
I should have mentioned Ryan Brown was very reasonable. A bit of a delay in shipping across the border - even back then.
tubtar - There's no passages inside. Volume capacity is determined by the little flapper valves. If a npt to hose nip is being used, it may be worth using one that has a smooth transition and ease the sharp edges on the ID. A lot of times I've seen the worst transitions on dual feed hard tube to the carb. The inside where it splits from single 3/8 tubing can often be improved.
It would be great if someone like RobMc packaged a higher capacity pump (more valves) in a smaller body so it would work with the 70 up water pumps. Maybe 4 or 5 valves instead of 6. It would still be better than the typical 2 or 3. The other solution would be a pre-70 water pump in aluminum. Then we all could use the 6 valve fuel pumps with no issue (other than a bunch of us would be moving our radiator outlets to the other side.)
has anyone used the race pumps they look pretty cool
