Best oil pan for alterkation
Big Block A body Tech
  1. roccodart440
    roccodart440 Well-Known Member
    5,723
    4713
    Apr 19, 2010
    Local Time:
    11:52 AM
    I'm switching right now from the stock setup to an alterkation. I know they allow for more oil pan clearance and choices.
    What do you guys recommend?
    And my existing pan is FUBAR'd so that's part of the reason i'm buying a new one. It's been hit one to many times..
  2. rumblefish360
    rumblefish360 So close, yet so far away FABO Gold Member
    39,972
    11516
    Jun 21, 2005
    New York, on a Island
    Local Time:
    11:52 AM
    Rocco, your running a big block?
  3. dartcuda1
    dartcuda1 67 Barracuda 500ci 6sp
    1,661
    74
    Dec 2, 2008
    Malvern Pa
    Local Time:
    11:52 AM
    Milodon makes a oil pan for that setup. I bought a Charlies oil pan for mine. Mark
  4. famous bob
    famous bob mopar misfit
    18,421
    7783
    Aug 14, 2011
    okla
    Local Time:
    10:52 AM
    I found an old funny car oil pan from back before dry sumps, had to modify the front a small amount , so far so good. milodon single line p/u, had to shorten the single line a little. saved some $$ on that deal.
  5. abodyjoe
    abodyjoe Well-Known Member
    21,214
    6691
    May 22, 2004
    Berlin,N.J. 08009
    Local Time:
    11:52 AM
    if ya call bill i think he would be able to give you a list.
    pretty sure a stock type would fit. i think he likes the Milodon road race pan.
  6. 440dartsport
    440dartsport Well-Known Member
    607
    131
    Oct 14, 2010
    Kewaskum, WI
    Local Time:
    10:52 AM
    Good luck trying to get a hold of Bill. We bought 3 kits from him at one time and we had issues with the master cylinders in the kits not working. Tried getting a hold of him for a few months and said screw it and just bought new ones.
  7. Purple Haze
    Purple Haze Well-Known Member
    2,216
    26
    Apr 5, 2010
    AridZona
    Local Time:
    9:52 AM
    I use a Charlies with external oiling you can have him make it either way just tell him it is for a BB with the RMS AlterKtion and if you want to use a swing pickup or not. The single line Milodon may not fit because of the steering rack and it hangs lower than the Charlies. Don,t know about the RR pan just that it is internal oiling.
  8. roccodart440
    5,723
    4713
    Apr 19, 2010
    Local Time:
    11:52 AM
    Yes, 440 RB
    I've never had trouble getting a hold of him. Sorry to hear you did.
    Joe, I'll give him another call. When we first spoke he just said nearly any pan would work.
  9. roccodart440
    5,723
    4713
    Apr 19, 2010
    Local Time:
    11:52 AM
    I called Bill.
    He said the best pan that will fit his system is the Milodon 31580
    He also said that Charlies makes a pan specific to the Alterkation.
  10. challenger57
    challenger57 cuda57
    207
    15
    Sep 21, 2007
    york, pa.
    Local Time:
    10:52 AM
    I am using a milodon low profile pan in my 63 valiant 400 BB and an alterkation k frame with no problems of fit. I do however have low ground clearance to the pan 3.5 inch and that is with the adjustable shocks cranked WAY up. I think I am going back to a stock pan so I can lower my shocks down some so it is not such a stiff ride. After I get my new stock pan and verify all is good I am considering selling the LP pan. The low profile pan is 7 inch deep compared to stock of 5.25 inch.
  11. AndyF
    AndyF Well-Known Member
    1,912
    2108
    Feb 23, 2009
    Oregon
    Local Time:
    8:52 AM
    The Milodon 31151 is designed for the tubular K-frames. I happen to a new one that is for sale if you're interested.
  12. HemiDenny
    HemiDenny HDK Suspension FABO Gold Member
    8,090
    1695
    May 31, 2006
    NW Ohio
    Local Time:
    10:52 AM
    I like that pan....nice and shallow and slated for my "next " build.....my Hemi driveline in a not-so-street Duster body.
    PM me a price if you still have it.
    • Thanks! Thanks! x 1
    • No rush
      No rush Well-Known Member
      71
      6
      Mar 26, 2013
      Australia
      Local Time:
      12:52 AM
      Hey mate, I have a 440 with a Charlie oil pan on it, due to using an alterkation front end.
      By any chance do you know how much oil to put in the engine with that oil pan.
      The milodon 22070 dip stick I have doesn't have any markings on it.
      Cheers
    • dartcuda1
      1,661
      74
      Dec 2, 2008
      Malvern Pa
      Local Time:
      11:52 AM
      9qts
      • Like Like x 1
      • No rush
        71
        6
        Mar 26, 2013
        Australia
        Local Time:
        12:52 AM
        Thank you so much for the reply
      • famous bob
        18,421
        7783
        Aug 14, 2011
        okla
        Local Time:
        10:52 AM
        My 7 qt, old aluminun funny car pan is shaped like the one above .
      • oldkimmer
        oldkimmer FABO Gold Member FABO Gold Member
        17,752
        5558
        Nov 11, 2006
        Kindersley, Saskatchewan,
        Local Time:
        10:52 AM
        I have this pan. Kim
        • Like Like x 1
