TommieDuster76
Can anyone recommend a parts supplier for a 383 build? looking for bearings, rings etc. for full stock rebuild.
Thanks for that!I agree on Summit racing. And if you are ready to order stuff before the end of the month check with GTX JOHN for a ten percent off coupon for Summit Racing.
Summit 10% Discount Coupons still available
Thanks for the advise!honestly, summit or rock auto should be able to hook it up. if you don't mind sourcing from several suppliers and know what you want specifically you could maybe get a little bit better pricing off ebay
the good part about summit is that their returns are easy. also, they generally list mfg. origin in the part descriptions.I'm a big fan of Summit. My only concern is quality parts, particularly with internal engine parts like cam shafts, lifters, bearings and rings. Imported parts concern me!
Not a bad idea!the good part about summit is that their returns are easy. also, they generally list mfg. origin in the part descriptions.
this day in age, cams & lifters are of particular concern regarding quality. depending on the direction that you're taking the build i'd be inclined to clean up and reuse what you've got or send it out and have the cam reground and the lifters refaced.
