Best Pass This Season
440dartsport
Kewaskum, WI
Here is a video of the best pass I had this season with the Dart. 10.2 at 135mph. Pump gas 4 speed street car.
[ame="https://www.youtube.com/watch?v=325D4JiFCS0"]Dodge Dart 4 Speed Drag Race - YouTube[/ame]
Thanks guys. It is a blast rowing through the gears. And this trans has been rock solid and it doesn't even have a slipper clutch.
Yes. It's a 18 spline hemi trans. I sent the gears and shafts out to have them shot peened and chryo treated at liberty. I am running a mr gasket vertigate shifter.
awesome pass. stock 4 speeds are a handfull but a fun handfull !!!
Did you launch at what I recall was 4500 RPM or ?
same exact setup I have in my duster. glad to hear it's surviving for you. I had problems prior but now I have the full Liberty treatment so I too should be good.
That sure does get me excited, we have nearly the same motor set up. Is that full exhaust? Can't wait to get mine done!
It's full exhaust on the street but I drop it when we go to the track. We were playing around a lot with different launch rpm. We tried between 4,500 and 7,000. The track wouldn't hold it above 6,000 but it left smoother with more rpm so most of the passes were about 6,500 launch. Thinking about changing up the rear suspension to get it to hook with more rpm and try to dip into the 9's.
[ame="http://www.youtube.com/watch?v=vDOHw6bL-is"]Dodge Dart 440 4 Speed - YouTube[/ame]
This was a pass when we launched at 4,500 rpm. It hooks better but gets a little violent.
