best way to remove the under dash assist spring???
swinger340
Maine
What is the best way to remove this clutch pedal assist spring without ruining it?
yep it does done it many times with assembly out shouldn't be too hard with it in
I did it using washers with the assembly still in the car. I still had to use a little force to get it out. If I had not used the washers I doubt I would have gotten out in one piece.
I used quarters!!!! Go figure--Yep washers same thing!!!! They are tougher springs than you think,I remember when passon sent me mine I thought he was joking with the size of the thing!!!!!!--Steve
