Bf Racing tubes.
BigStrok3
Mopar!
St.louis area
So I went and bought some of these from a local preformance shop for a my ET Streets. When I get them home and out of the package the valve stem wouldnt go threw the valve hole on the rim so we drilled it out to make it fit. I was wondering if anyone else has ran itno this problem? Also Under the vale stem on the tube there is about a 1/4 of rubber that connects the stem and tube and i was wondering if that stayed on the inside of the rim. not sure if it is also supposed to go threw the valve stem hole beings this is the first set of tubes ive ever had mounted. Thanks
