[FOR SALE] Big Block electronic distributor with tach drive & tach
737jetdr
Martinsville, In.
I have a Chrysler performance electronic distributor with tach drive, the cable and a Moroso tach for sale. p/n 4120942 . I believe it works in most big blocks including 426 hemi (do your research). Worked fine when removed. I will not be using as I am going back to small block. Wires have been spliced by the previous owner. Holes drilled in bracket are from previous owner. Face of tach is a little faded (see pic).No light or wiring for the tach but I'm sure it can be found. Asking $450 plus shipping from S.E. Michigan 48191. Thanks.
Nice setup the numbers come up 1980 Mopar Performance RB tach drive. Good deal for someone.
