[FOR SALE] Big Block MP .620 solid camshadt + lifters
Jeremiah (jd)
Rogue River, OR
Hello,
I have a used Mopar Performance .620 lift solid flat tappet camshaft and lifters. These parts were in an engine I purchased with what appears to be low run time. The lifter placement was preserved upon disassembly.
Asking $300 + shipping
Do you have the cam card for this grind to show duration @.50?
The math used by Chrysler adds up to 275 at .050 but....others have measured them out in the mid 280s at .050
I am pretty sure there were multiple suppliers of the purple shaft line of cams over the years also. That alone could count for some variation. Bottom line is a person would be hard pressed to find a high lift mechanical camshaft and lifter set for 300 clams
Agreed
