[SOLD] Big Block Spool Type Motor Mounts $25
gregpurcell
Greg Purcell
Near Savannah, GA
This is a used pair of big block B Body "spool type" motor mounts from a 73-77. These are NOT conversion mounts! You have to have a factory big block B body K frame (different from small block) or an A body K frame that has been modified for big block.
I got these mounts in a box of parts. Someone tack welded a nut to the edge of one (WTF?)
I cut it off with a die grinder and cleaned it on the wire wheel. (before/after pics below)
The rubber insulators have some cracks but may have life left in them. Sorry, I only have one bolt.
Located in Savannah, GA I need to get $25 plus the ride (probably $15 in a flat rate box)
Thanks for looking!
