It's a 69 383-s fastback barracuda. Original 4 speed, bench seat, fast ratio steering, tach, stripe delete B5 blue exterior with standard black interior. One of 331 big block 4-speed fastback formula-s barracudas.
I've had a 440+6 in it with 2" CPPA headers for twenty years. I had to modify the z-bar to work with the CPPA headers that were not designed for a 4-speed and although it worked, it wasn't great. I also had to lift the engine a bit to work with the headers
I am going to modify the tri-ys to fit the 4-speed, put a 2.5" exhaust with x-pipe and new stainless steel tips, lower the engine down to the stock location, and put in a centerforce clutch.
Rod
