gregpurcell
Greg Purcell
This is a box of miscellaneous 4 speed transmission shifter rods and arms that I have collected over 30 years of working on 60's-70's Mopars. It has been a lifesaver when you want to modify something and not screw up an expensive set of new rods. Now that I'm retiring, I need to accept the fact that I'm not going to doing as many engine swaps as before and let some of this stuff go. If you do it daily, this box will be indispensable!
Located in Savanna, GA I'd like to get $60 plus the ride for the lot. Most of these rods should fit in the large flat rate box for $20 or I can bring them to the FMA show in Ocala FL this weekend.
