Bigger torsion bar?
hotrod68
hayfield mn
Will running a bigger torsion bar help slow down the rise in my front end? Currently running /6 bars with adjustable QA1 shocks set on full tight on rebound and the car still comes up way to fast and wants to unload the rear. Thanks for any info.
Yes, running a bigger diam [ stiffer ] T bar will slow the rise of the front end.
Agree with Bewy. You can take some of the preload out with a larger bar.
That said, and not knowing what you have out back, you may look their for a solution. Many stock eliminator cars have quick rise and hit the tires hard without issue.
