I currently have 440 with KB pistons 10.1 compression, Performer RPM manifold, Holley 750 DP, 3.73 rearend gears, 3000 stall, headers 2 1/2 exhaust, with stock 906 heads & rocker arms and competion cam 431 / 434 I am looking for cam suggestions. it's in a 65 Dart that weighs about 3,000lbs.
First what would be the biggest cam I could use before I would need to do some work on the heads (double valve springs, and new rockers etc) Second what would be the optimum cam specs if I did do some work on the heads? Looking for something streetable, but with better upper RPM power than what I currently have.
