Bleeder valve
65Cudafix
Bemidji, MN
65 Barracuda, 273ci 2v, drum brakes. Brand new to me so Safety first, do the brakes
(See photo)...
Replaced all the pads, hardware, wheel cylinders and a line to the passenger rear. Note, cylinders came with bleeder valves already installed (yeah!)...
Finally got to bleeding the lines and noticed that the driver side front cylinder has a 1/4 bleeder valve while all the others are 5/16..
PITA! the hose used for the others is too large and swapping wrenches et al...
Is there a reason for this, or just cheap Chinese parts. Suppose that I can swap out a 5/16 valve?
Thanks in advance for your opine.
65Cudafix
It's to help offset the weight of a driver in the car.
Not!:D
Probably different suppliers, or possibly even just a different manufacturer.
Clean up one of the old 5/16 ones and use it if it will work out that way, and if it bugs you that much return them until you get what you want.
