Blew power steering return hose
Suspension, Steering and Chassis
  1. briwill70
    briwill70 Well-Known Member
    111
    30
    Feb 2, 2020
    Portland, Oregon
    Local Time:
    11:12 AM
    After rebuilding the transmission, brakes and front suspension, I finally got my 65 dart back on the road this weekend. Power steering was working intermittently and fluid was foaming but not making any noises. Was about 15 miles down the road when the steering started to bind up. I pulled over and right as I did, the PS return hose blew (loudly) Both hoses were new. How did so much pressure build up in the return line? What is the issue here?
  2. 67Dart273
    67Dart273 FABO Gold Member FABO Gold Member
    45,017
    12611
    Oct 14, 2010
    Idaho
    Local Time:
    11:12 AM
    Something had to have plugged it. There should be NOTHING to build pressure between hose and pump. Either that or it got kinked somehow. I'd also suspect the hose is rotten/ liner collapsed
  3. briwill70
    111
    30
    Feb 2, 2020
    Portland, Oregon
    Local Time:
    11:12 AM
    That is why I'm so confused. Hose was new. Not kinked. Nothing plugging the return to the pump.
    The pump has been leaking from the cap when the fluid is foaming. Excessive pressure from the foaming?
  4. Tooljunkie
    Tooljunkie King of cobble/master of the broken bolt FABO Gold Member
    15,687
    15263
    Jul 22, 2017
    Manitoba
    Local Time:
    1:12 PM
    Foaming is usually from a bad pump seal.
    Did you use power steering return hose or something else?
    Fuel line wont handle it.
    Transmission cooler hose is iffy too. Ps return line is pretty tough,compared to regular gas line.
  5. 67Dart273
    45,017
    12611
    Oct 14, 2010
    Idaho
    Local Time:
    11:12 AM
    Trans hose should handle that there should be almost no pressure there. "I suppose" there could have a bunch of air that got hot and expanded if you didn't get it out of there. Foaming when partly empty or refilling is common, they can make a mess. I've done stuff like fill it, start for a few seconds, let it sit. It will burp. Try again. After a few tries it usually stabilizes some, work the wheel back and forth slow to bleed
  6. briwill70
    111
    30
    Feb 2, 2020
    Portland, Oregon
    Local Time:
    11:12 AM
    I read some other forums where people had similar issues. Looks like the pump may be leaking pressure into the reservoir and needs to be rebuilt.
  7. Demonracer
    Demonracer 71 Demon 00 Ram 16 Chrysler 300S 05 Caravan FABO Gold Member
    3,812
    1745
    Jan 31, 2010
    Cleveland, Texas
    Local Time:
    1:12 PM
    Foaming is a definite sign there is air getting into the system somewhere.
  8. AJ/FormS
    AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
    19,189
    7088
    Jan 19, 2014
    South-Central Manitoba,Canada, 900ftelevation
    Local Time:
    1:12 PM
    Hmmmmm that's a toughy.
    I might bet that you got a Federal pump, which I would asap remove and drive over it with an asphalt packer. You know, I studied that Federal, and it looks like a great design, but I just never had any luck with those.
    Got me a Saginaw, and that was the end of my troubles.
    I'll guess your relief valve stuck.
  9. briwill70
    111
    30
    Feb 2, 2020
    Portland, Oregon
    Local Time:
    11:12 AM
    Well I removed the pump and discovered a screen filter down in the return inlet on the pump. Totally blocked from what I can tell. I removed it and cleaned it with carb cleaner and still can't blow air through it. Put the pump back on the car without filter and it's making terrible noises now so will seek out a new pump or try to rebuild. Looks like a Federal pump but return line is huge. Heater hose size Not fuel line size. Same size out of steering box.
  10. briwill70
    111
    30
    Feb 2, 2020
    Portland, Oregon
    Local Time:
    11:12 AM
    Pics
  11. briwill70
    111
    30
    Feb 2, 2020
    Portland, Oregon
    Local Time:
    11:12 AM
    Well, no luck finding a replacement pump or even a rebuild kit. Any suggestions? Sucks that after so much effort, this is what's keeping me from driving the car.
