ESP47
I'm replacing part of the trunk floor in my Barracuda. I butt welded the patch panel in. It's not perfect but I'm proud of it since I'm very much a novice welder. There's some warping here and there but it came out ok. If I want to get the trunk floor looking pretty smooth, would it be ok to use body filler here? In my garage, I have a brand new can of Evercoat Metal 2 Metal and a new can of Rage Gold filler. Should I place the Metal 2 Metal across the areas that were welded and then use the Rage Gold on the flat part of the panel? It'll never look perfect but I'd like it to at least look presentable if I have the trunk mat up. Then again if the filler is going to crack or cause problems back there I'd rather just not even mess with it. Thanks.
