mopardemon340
putting 408 stroker in a 72 demon and we are looking for 400 to 500ph... at what HP would you recommend we put a frame connectors in to stiffen it and stop twist.
my thoughts exactlyIt helps even with a slant six
you mean like a roll cage with front longitudinal bars or a 4 link type system with cross bracing.. ??the other thing i wonder about is why strength to the front as well as the rear is rarely considered?
for a unibody car it's a must!!For a 4spd it is a must
honestly, I didn't consider if it is or not.. all these modifications work either way..oops..i thought this was a street car..
intrusion and welding to floorpans is the stiffest way.i used 2" x 2" square tubing, cut the floorboards once tubing was welded to the sub frames I welded the floor boards to the tubing, it is super stiff. Intrusion into floor boards not a problem.
Us Car Tool | Restorations, Unibody Stiffening, Body in White, Restoration ToolsWhere did everyone get there frame connectors? Also, never heard of a torque box. Im a newb. Half way through my first build. Mag swap.
