greyghost340 GreyGhost 340 Joined Dec 5, 2014 Messages 308 Reaction score 89 Location New Balimore MI Oct 18, 2020 #1 Do they make a Drive Shaft Safety Loop that bolts on to the cross member for a 1970 4 speed Duster? This will prevent drilling threw floor of the car?
Dfr360cuda Diagnosis... Plum Crazy. Joined Aug 30, 2012 Messages 2,652 Reaction score 2,267 Location Finleyville, PA Oct 18, 2020 #2 I thought someone made one that bolts to the transmission crossmember
S Stephen Mulkey FABO Gold Member FABO Gold Member Joined Nov 29, 2016 Messages 1,101 Reaction score 640 Location California Oct 18, 2020 #3 Check out US Car Tool.
C charger426 Well-Known Member Joined May 5, 2014 Messages 1,071 Reaction score 320 Location MoparLand Oct 18, 2020 #4 Several make ones that use the transmission cross member bolts. eBay, USCartool, and Mancini all had them when I bought my years ago
Oldmanmopar Going left turning right FABO Gold Member Joined Jan 8, 2009 Messages 13,336 Reaction score 12,989 Location Danielsville Pa. 18038 Oct 18, 2020 #5 This one is for a GM but I believe they make a mopar one. Pretty easy to make though. https://www.ramairrestoration.com/p...drill-driveshaft-loop-all-gm-w-turbo-400.html
Biff Cheep not easy Joined Jan 30, 2017 Messages 10,087 Reaction score 22,637 Location Canada Oct 18, 2020 #6 Just keep in mind NHRA rules 2in wide 1/4in thick no farther than 6in behind front u joint 360deg encapsulation
Davezilla Well-Known Member Joined Aug 29, 2019 Messages 134 Reaction score 53 Location Michigan Oct 18, 2020 #7 PM sent.
dartindanno Well-Known Member Joined Aug 25, 2011 Messages 5,234 Reaction score 10,714 Location Kenosha, WI Oct 28, 2020 #8 I used this from US Car tool, installs to the cross member
greyghost340 GreyGhost 340 Joined Dec 5, 2014 Messages 308 Reaction score 89 Location New Balimore MI Oct 28, 2020 #9 Yes, thank you. Just purchased one.
