Bolting Engine to Stand
RobbAdams
Calgary Albera
New motor arrives tomorrow, and I put the stand together Tonight.
What size / type of bolts should I be using to bolt my la 360 to the stand?
I guess I need Diameter, thread type, and length?
Bolts are 3/8 NC and I use 4" long grade 6 with a washer against the engine stand. My engine stand is 3 inch thick where it bolts to the engine, so check to see if yours is the same, and just add an inch to get bolt length. Two bolts you will need nuts for them as they bolt through the block where there is no thread.
I think thats right, but then again it's midnight here!
haha i jsut did this the bolts are 3/8-4-16 you need lots of spacers and washers and i used grade 8
