1. christmas53
    christmas53 FABO Gold Member FABO Gold Member
    94
    18
    Aug 1, 2014
    Florence s c
    Local Time:
    8:06 PM
    I got my new borgeson steering box installed. It is like day and night in the handling. I jacked up motor on driver side and pulled old box out from the top after pulling the header. I had to shim the motor mount 1/4" to get some clearance with the dougs headers. Cut 3/4" off the steering shaft and installed the ujoint coupling. I would have like to had a little more room between the header and the box but at lease it is not hitting. I got everything from summit to make the change over. The old box was getting a little scary even after trying to adjust it. I can now drive this 68 cuda with one finger. Thanks to borgeson and summit. This car is pleasure to drive now.
    • Like Like x 1
    • Agree Agree x 1
    • CCHHAARRGGER!
      CCHHAARRGGER! Well-Known Member
      129
      70
      Dec 5, 2017
      california
      Local Time:
      7:06 PM
      I am guessing power steering. Also someone makes a coupler that requires no cutting and is like the factory joint.
      • Agree Agree x 1
      • Gdub310
        Gdub310 Well-Known Member
        148
        157
        Jul 10, 2018
        Los Angeles
        Local Time:
        5:06 PM
        • Agree Agree x 1
        • autoxcuda
          autoxcuda Well-Known Member
          6,536
          811
          Apr 6, 2007
          Local Time:
          5:06 PM
          Do you have a pick showing the place on the steering box that hit the header?
        • clifftt
          clifftt Well-Known Member
          2,270
          655
          Nov 13, 2007
          Concord, CA
          Local Time:
          5:06 PM
        • rednesss
          rednesss Well-Known Member
          1,450
          149
          Mar 4, 2006
          Eugene, OR
          Local Time:
          5:06 PM
          800% markup???
        • Kern Dog
          Kern Dog FABO Gold Member FABO Gold Member
          4,865
          7256
          May 23, 2010
          Granite bay CA
          Local Time:
          5:06 PM
          The coupler in the picture is a hybrid between the Borgeson steering box splined shaft and the stock type Mopar coupler. This allows a man to keep their steering column intact. Other methods require cutting the steering shaft and fitting a U-Joint type coupler on it. I agree, the $200 is pretty steep, like BAC really passed on all the development costs to make it.
          BAC.....Sounds like Balls Against Chin....:poke:
        • BigBlockMopar
          BigBlockMopar BigBlockMember
          1,756
          757
          May 1, 2011
          Netherlands
          Local Time:
          2:06 AM
          You can buy the splined adapters at Summit and simply weld them onto your existing steering coupler.
          I recall having paid some $10 for mine years ago, but I see they've almost doubled in price already.
          I think BAC simply sells you a brand new complete steering coupler unit with this adapter already welded on. Has some markup, but for this part it doesn't seem that much out of line.
          Retrofit Power Steering Box From Borgeson - One Good Turn
          • Agree Agree x 1
          • MileHighDart
            MileHighDart Well-Known Member
            4,343
            3920
            Jun 3, 2004
            Lyons, CO
            Local Time:
            1:06 AM
            Did the new box get rid of the classic “on center slop” that most of our old mopars have ?
            Considering the borgeson box myself
          • abodyjoe
            abodyjoe Well-Known Member
            20,974
            6335
            May 22, 2004
            Berlin,N.J. 08009
            Local Time:
            8:06 PM
            maybe @GMachineDartGT can answer the question for ya.
          • christmas53
            94
            18
            Aug 1, 2014
            Florence s c
            Local Time:
            8:06 PM
            It's close but not hitting
            Yes, before I had to steer with one hand and move the steering wheel up and down. If you were on an uneven road it got to where it would dart. So I bit the bullet and went with the borgeson power steering box. I love it I can drive it with one finger on the wheel even on the bad roads.
            • Thanks! Thanks! x 1
            • Agree Agree x 1
            • 67Dart273
              67Dart273 FABO Gold Member FABO Gold Member
              45,859
              13604
              Oct 14, 2010
              Idaho
              Local Time:
              5:06 PM
              .............You.........guys..........are..........sure..........causing........temptation here.......
              • Agree Agree x 2
              • Stone 270
                Stone 270 Member
                23
                18
                Mar 27, 2015
                Richmond Va
                Local Time:
                8:06 PM
                I aslo installed the borgeson box this summer. The car is currently a roller in a tiny garage
                in order to work on it I have to roll it out of the garage. It now takes 1/3 the effort due to the
                steering tightened up :steering:
                • Gdub310
                  148
                  157
                  Jul 10, 2018
                  Los Angeles
                  Local Time:
                  5:06 PM
                  Yeah, you definitely don't want your Cuda to Dart :)
                  • Like Like x 1
                  • Agree Agree x 1
                  • Danizanon
                    Danizanon Well-Known Member
                    81
                    13
                    May 22, 2018
                    Brazil
                    Local Time:
                    10:06 PM
                    If I install a fast ratio pitman with original power steering box it will have a similar result?
                  • JoesEdge
                    JoesEdge Well-Known Member
                    1,068
                    248
                    Jun 6, 2013
                    Downey, CA
                    Local Time:
                    5:06 PM
                    I've been running this steering box for about a year or so. Been good so far. My Doug's Headers hit in the same place too.
                  • autoxcuda
                    6,536
                    811
                    Apr 6, 2007
                    Local Time:
                    5:06 PM
                    You will have 12:7 ratio steering
                    But the new/different pitman will not change any sloppiness in the box. It probably will give you more resistance when turning that makes steering feel firmer.
                    • Agree Agree x 1
                    • autoxcuda
                      6,536
                      811
                      Apr 6, 2007
                      Local Time:
                      5:06 PM
                      What condition was your old steering box?
                      How much difference is the new one? What kind of difference?
                    • jos51700
                      jos51700 Hemi Orange you glad that Hillary isn't president?
                      5,427
                      2129
                      May 24, 2009
                      Bel-Ray
                      Local Time:
                      7:06 PM
                      I've thought about this for the weight savings but....
                      I have a fresh rebuilt power chuck from Firm Feel in the car now. I'm very happy with it and wondering if I'll see the same improvement.
                      So far, everyone loves that Borgebox.
                      Also wondering if this would apply to a big block a body with power steering
                    • JoesEdge
                      1,068
                      248
                      Jun 6, 2013
                      Downey, CA
                      Local Time:
                      5:06 PM
                      My old box was really sloppy. It was scary sloppy at time when you're driving by parked cars and you fear it deciding to veer towards the cars. It's tighter now than before, but since I'm now running 255 tires in the front it does still tend to follow any rut in the road. When the road is good, I can hold it steady with just a finger.
                      You were at the South Bary Mopars Rock-o-La thing this past Saturday right? I saw your Barracuda (I think). Too bad I didn't see you, I would have showed you the steering box.
                    • autoxcuda
                      6,536
                      811
                      Apr 6, 2007
                      Local Time:
                      5:06 PM
                      I saw your car driving by. Probably when you were leaving
                    • christmas53
                      94
                      18
                      Aug 1, 2014
                      Florence s c
                      Local Time:
                      8:06 PM
                      My old box was loose and a handful to drive. With the borgeson box it's like driving a new car.
                    • GMachineDartGT
                      GMachineDartGT Senior Member
                      1,641
                      280
                      May 9, 2006
                      Huntington, NY
                      Local Time:
                      8:06 PM
                      Its always interesting to hear opinions on my products.
                      I took the initiative to produce a bolt in product so you don't have to ruin your column along with custom hydraulic fittings for a direct bolt in product and I still get bashed.
                      • Agree Agree x 3
                      • Like Like x 1
                      • rednesss
                        1,450
                        149
                        Mar 4, 2006
                        Eugene, OR
                        Local Time:
                        5:06 PM
                        If I apparently didn't like the feeling of having it broke off in my ass every time I bought a part for a Mopar, I guess I'd buy a Chevy.
                        • Like Like x 1
                        • torred0319
                          torred0319 Well-Known Member
                          113
                          8
                          Jan 3, 2009
                          Local Time:
                          7:06 PM
                          I bought the BAC coupler. I have not installed it yet but looks like a good peice. My time is worth money. Could i make one yes, but why? Realistically for the amout and time it would take to make one i'm better off just buying one.
                          • Agree Agree x 3
                          • Like Like x 1
