Brake Booster (74 Dart)
I don't have one but I had one go out recently.
I converted it to manual and used a trucks almuminum mastercylinder. It was a little cheaper, I dropped 20 lbs off my nose and I never have to worry about it again.
I don't have to worry about having too much cam for my brakes either.
What year truck??
Mid eighties. It is the aluminum one with the two screw off tops. A buddy made a spacer for me (you need a metal lathe) and I cut and welded a "B" body pushrod to the right length.
Or, check over at Moparts. There is a guy that sells everything you need. He keeps an ad in the parts section and sells this as a kit.
