1969dodgedart
Big Block 440
I'm looking for picture or diagram of brake / fuel line clip positions/ orientation for 1969 dart ? The pictures i took before disassembly aren't cutting it . Thx in advance.
Yup got all new clips for fuel/ brake lines . Also I can see all the holes for clips but wasn't to sure how lines clipped in and there are clips with bolts for both fuel/ brake lines . Could not see where they go along both paths. Thx for that picture, shows which way lines get clipped in.Actually, if you bought preformed lines just put them on the car and look for the holes in the frame rails near where they are routed. If will become pretty obvious where they go. If you have any questions after, post again.
The only one I can easily get to on my 68 is the last fuel line clip on the right frame rail in the engine compartment. You probably know new clips are available.
