gtxdude
Pulled my rear wheels off to check back brakes. On my passenger side rear brake the pad has a crack in the middle. Brakes work fine but I'm wondering if pad should be replaced? thanks
Agreed.Spring looks a little wonky
Thanks everyone, yes shoes not pads, brain fart. I'll check springs also
if it was me I would change the shoes cheap and easy
Considering how cheap brake SHOES are, I would replace them.
Hardware is cheap insurance against componenet failure.
